8v-of-fury
BAMF FORD
Ok. The truck is not mine. It is my gf's mothers work truck. She is trying to get rid of it because she says its old, doesnt start right, doesnt run right, and has no power.
I told her no! do not get rid of it! I WANT IT!! I told her listen, its 22 years old. It's got 705K on the clock, her husband was good mechanic.. But diesels!? noway. the glowplug system doesnt even work! due to two not even connected! So i told her, I can fix the starting issue, and it runs Like a top. I told her i think shes smoking something. lol
Its an '87 F350 with the 6.9 and its n/a. It has been abused and put away wet most every time its been driven ( i want to smack her for it too lol). I manually jumped the gp's to get them to glow and it fires up in under 7 seconds in probably 0-5 degrees celsius. For 705K this engine is pretty tight.
NOW, she had it at a mechanics some time last year, and they changed the oil and said there was coolant in it. Now I know it points to a HG, but all the other symptoms aren't there. So what i think it is.. is a small leak in between a coolant passage and an oil drain. The work to have it torn down and have HG done im assuming is gonna be astronomically more then the truck is worth. So I told her, more frequent oil changes. For practically nothing she has gotten 9 solid years out of the old girl.
ok. So if i can convince her to keep it until i can buy it from her, will running synthetic oil along with that special type of coolant reduce the amount of damage the coolant will have in the oil? I mean i know its bad, but she has run it for a year like this and i have driven it.. It runs GREAT i love it!
What all do you guys think I should do?
