If you have a lower end problem, you can count on turning the crankshaft and while, in theory, you could drop the crankshaft out and replace bearings without disassembling the rest of the engine, that's probably not the best long term idea unless you are short money. Half measures often come back for a meal of gluteus maximus.
Okay, so let me ask you a hypothetical... 1. Given the small pile of metal slivers I found on the oil pan magnet (WHY didn't I take a friggin' PICTURE!), the 2-3 quarts I got out when changing the oil, and the volume of this knock increasing all in the same period is there even a point to removing the oil pan, pickup, etc. to inspect it? Then inspect remove bearings look for crank damage and then put it back together to get it out of the shop? There are only 3 scenarios I can imagine here. 1. I pull pan etc and there is damaged bearing(s), I remove damaged bearing and crank is either damaged or not. If yes, than crank needs pulled so engine should be pulled in which case a complete overhaul would be the logical step. If no, then just put it back together and look elsewhere? I would still want to replace all the bearings just in case so then the crank would STILL need to be removed - right? I get valve covers off and inspect or do leak down and find a bad valve well springs and seals for sure, heads should be cleaned and spec'd by machine shop ($500 each local quote) that's not guide install or new valves, rockers, pushrods, etc. If I'm doing one valve well should probably do all of them to be safe (engine has 215k 190k of that unknown) well if valves then rockers pushrods, etc.
I don't have the cash flow to do any of this and the overhaul **** is time consuming, expensive, and takes a dedicated shop... Guess how many of those I got...This truck was supposed to be and I still want it to be my daily driver. The Regular cab and two kids plus work **** don't add up. Seems like I'm back to the option of replacing the whole engine with a plug and play used.
I'm not trying to rant I think I'm just trying to accept the reality of the situation here. If I am missing alternatives please fill me in.
Okay, been up 30+. Gotta sleep a little and get the girlies!!! If any of this doesn't make sense then blame my subconscious because I am pretty sure I may be sleeping already..... Thanks for your help guys.
