my valve train geometry, is spot on.
the roller meets the valve stem directly in the center with the bolt and the pedestal installed.
if I wanted to decrease the compression with a thicker headgasket, the geometry inbetween the
pedestal and the valve will not change. only the dimension inbetween the lifter and the adjuster on the rocker.
these rockers are adjustable. if I ever did need to shim the rocker, it can easily be done inbetween the head pedestal and the rocker pedestal.
ive already been through all of this.
I will not be running the decomp HG's
so its pretty much a moot point
