Should be able locate plugs simple nuff
THANK YOU EVERYBODY FOR YOUR WORDS OF ENCOURGEMENT/NOT SO ENCOURAGEMENT..
I have found the issue.
let me start off about how my morning went.
first off I pulled the drain plug on the oil pan to find about 8 oz of coolant in the bottom.
not happy.
so I pressureized the coolant system.
and found 2 external leaks!!!
I was also applying 16-17 psi into the coolant system ( on a 14 pound system)
while I waited for a while to see how much it would leak down, I did a leak down test.
Initial pressurization
pulled all my refurb'd (CDI's Misters) injectors out, and 7 of them are leaking...
that explains the shake at higher RPM's
I will be doing a pop test on them later this evening.
I went all around and found all 8 cylinders to be "slight to set"
all escaping air (100 psi) was coming from crank case, the rings are not fully set, but there doing a good job.
all 16 valves are in good shape, no air out of guides.
After 1 hour of 16.5 lbs,
It has dropped to 13-14
Off comes the intake and valley pan.
Thought of you... @Greg5OH
The intake gasket I would never reuse.
Dances like a preschooler and sings...
"Oneofthesethingsisnotliketheother!!!
Can you see the culprit?
the last picture is with the coolant system pressureized to 16 psi again.
water is definitely coming out through this plug.
I should have changed them when I got the heads back.
my machinist doesn't touch em because he thinks of me of rather capable of changing my own freeze plugs.
he has told me this a few times, I guess he never got through my thick skull
I usually change them all the time, but what can I say, im a pothead, and human(kinda) to boot.
another lesson learned.
will be replacing the plugs and lifters tomorrow after the lifters get here.
PLUGS?!??
I though those were just coolant ports that got blocked off by the intake manifold (sealed by the gasket)? How's coolant going to leak from there if your gasket is good?
nope there are 11/16" plugs in there, then the gasket goes over them, but you don't RTV it, or atleast I didn't, so... it leaked.
Well, it appears my heads (6.9) are different than yours. As you can see in the pic my ports aren't even round, let alone machined for a plug. Further, I remember when changing an intake manifold gasket about 2 years ago, a bit of coolant ran out of these holes and I scrambled with a rag to sop it up before it got to the crankcase.
I have a theory, `and it goes like this; Ford got complaints of coolant running into the crankcase every time someone removed the intake manifold, to remedy this problem, Ford worked out a freeze plug fix for these holes. Thus mechanics everywhere could pop the intake manifolds without draining the block, or flooding the crankcase.
Why is this important? Maybe it's not, but; consider this: I don't believe the seal of your freeze plugs is essential to engine operation. Thus, while you do have A LEAK at your freeze plug, it may not be THE LEAK. Unless your intake manifold gasket is bad as well, it shouldn't make any difference if the freeze plug is sealed or not.You must be registered for see images attach
