THANK YOU EVERYBODY FOR YOUR WORDS OF ENCOURGEMENT/NOT SO ENCOURAGEMENT..
I have found the issue.
let me start off about how my morning went.
first off I pulled the drain plug on the oil pan to find about 8 oz of coolant in the bottom.
not happy.
so I pressureized the coolant system.
and found 2 external leaks!!!
I was also applying 16-17 psi into the coolant system ( on a 14 pound system)
while I waited for a while to see how much it would leak down, I did a leak down test.
Initial pressurization
pulled all my refurb'd (CDI's Misters) injectors out, and 7 of them are leaking...
that explains the shake at higher RPM's
I will be doing a pop test on them later this evening.
I went all around and found all 8 cylinders to be "slight to set"
all escaping air (100 psi) was coming from crank case, the rings are not fully set, but there doing a good job.
all 16 valves are in good shape, no air out of guides.
After 1 hour of 16.5 lbs,
It has dropped to 13-14
Off comes the intake and valley pan.
Thought of you... @
Greg5OH
The intake gasket I would never reuse.
Dances like a preschooler and sings...
"Oneofthesethingsisnotliketheother!!!
Can you see the culprit?
the last picture is with the coolant system pressureized to 16 psi again.
water is definitely coming out through this plug.
I should have changed them when I got the heads back.
my machinist doesn't touch em because he thinks of me of rather capable of changing my own freeze plugs.
he has told me this a few times, I guess he never got through my thick skull
I usually change them all the time, but what can I say, im a pothead, and human(kinda) to boot.
another lesson learned.
will be replacing the plugs and lifters tomorrow after the lifters get here.
