For the wiring of the gauge this is the diagram they gave me. When nothing worked, I went and hooked the 12v directly to the positive battery terminal. Ground to negative. If this thing works anything like I thought it did shouldn't the terminal for red to the thermocoupler have power? because I could touch that lead directly to metal and there was no spark as if the power wasn't actually going through the wires to the probe to begin with. I tried the black thermocoupler wire as well just to make sure and it had no power from the gauge either.
The wiring diagram doesn't even make sense though. Totally ignore the light power stuff, and just look at the "ground" and thermocoupler black arrows, those have metal touching each other so how would the resistance of the probe ever send a different signal to the gauge to begin with? This whole thing seems jacked up.
Either way, I think I'm almost over this gauge system. I have a 1/8 threaded hole in the exhaust manifold, I can fit probably about a 2 1/2 or so probe in it, anyone have a better suggestion for a known good gauge I could install in the hole that's already in the manifold without re-drilling stuff? I really at this point don't care what the price is for a better known good working system I just after messing with this thing this morning don't think it's gonna work period.
