Happy I was able to help
And, fortunately, I had the recepits right at the front of my file folder. If I'm reading it correctly, the Ford part numbers are as follows:
Large: 1C3Z-6C610-BA (two needed) (these are the same on the new and old oil coolers)
Small: 1C3Z-6K649-BA (two needed) ("late" oil coolers after Block # 6.9D U2U 061494)
And, for the record, the "early" oil cooler inner rings are Ford part number E3TZ-6K649-A (4 needed), but IIRC Ford has discontinued these...I don't know if they're available from International or not, and I don't have the IH part numbers.
Also, I don't think Ford EVER updated the oil cooler diagram or install instructions in the FSM...which, I believe, is why there have been problems in the past with oil cooler assemblies. In the early oil coolers, the smaller O-rings HAVE to go into the headers...however, if you try to put the smaller O-rings into the headers on a newer oil cooler, you run the risk of cutting the O-rings up and therefore need to install the smaller O-rings on the bundle.
It's not the only misprint I've caught in the FSM, unfortunately...at least in my '84 FSM, it says that the thermostat gasket needs to go onto the block first, with the thermostat sitting on top of the gasket. When I put it back together, I took the FSM at face value even though it seemed to me that the thermostat should go in first...lo and behold, I ended up with a leak and had to take it apart and put it back together "right"...
