If oil temps is a fear going to a turbo maybe a small power steering oil cooler can be installed BEFORE the turbo.
Just s early norning wakeup thought.
![sly :sly :sly](/styles/default/xenforo/smilies/sly.gif)
Liquid to liquid heat transfer is 5 times more efficient than air to liquid. Oil temp up to 280* is not harmful, you can run synthetic up to 360*.
How are your oil pressures with this setup and where are you taking the oil pressure? I am seeing my oil pressure drop when the oil heats up and was thinking about this. I can see 4psi hot and 26psi cruising at 2000 rpm even with 15w40
iv long since removed:
Earl's Performance Temp-A-Cure 16 Row Oil Cooler #41610A
^ i went to install my plow for the first time,that first winter with the oil cooler mounted down there and it wasn't high enough.i broke it! so i replaced it and moved it up.the one i replaced it with was with a bit larger one:
Earl's 42500
