NapaBavarian
Dually driver 6.9
I'd like to convert to discs when I rebuild a rear axle, does anyone offer the bracketry, or is it something I'd need to come up with myself?
NapaBavarian said:I'd like to convert to discs when I rebuild a rear axle, does anyone offer the bracketry, or is it something I'd need to come up with myself?
zigg said:I'm just wondering how would this works with the factory master cylinder, which is designed to work both a drum and disc system, thus has 2 different sized pistons internally, and sends different amount of fluid to the rear than the front.
Would you have to replace the master cylinder also?
Zigg
towcat said:I like factory designed parts. been hunting for a '99 E350 cutaway dualie chassis for a disc brake rear. The memeber "Jaybee" was the first one to have done the swap and mod.
Zigg
zigg-zigg said:I'm just wondering how would this works with the factory master cylinder, which is designed to work both a drum and disc system, thus has 2 different sized pistons internally, and sends different amount of fluid to the rear than the front.
Zigg
towcat said:zigg-
i am running a f450 master cyl on my f350 with no negative results whatsoever.
