groovemonster
When I got my idit it suffered from lack of use. As a result, EVERYTHING LEAKED - power steering, transmission, oil, fuel, coolant - EVERYTHING lol. Around July of last year I stripped the engine down and rebuilt the fuel system, cooling system, and a lot more. The first day running it came back home on a tow truck lol [random failure of the neutral safety switch]! immediately after fixing that, the fuel system started springing leaks all over the place. Spent weeks chasing them and sealing them. Immediately after getting that done, my power steering return line blew a hole. Got that fixed and my coolant started leaking again!!! At this point I'm thinking my truck WANTS to leak everything. Got the coolant leak repaired and BAM! As if the truck knew it was time to start a new leak, the fuel system blew a major hole! It probably dumped a gallon of fuel in about 30 minutes. Got it home and told my wife about it. She - being the supportive and loving wife she is - immediately started laughing! Anyway, I got that leak fixed and now it has been over a month since any new leaks have started. The only leak it still has is the rear main seal. It isn't bad, it probably leaks about a quart per month, and i drive it daily. I might just let it be. Not sure if I want to keep pushing my luck lol
