Might as well add what I found in my filter head and what I'm going to do about it.
Heated failed, coating on the mounting disk is flaking off. After filter, all this after filter.
Going to be my fuel/water prefilter, using the bowl from the loose filter. Going to run a smaller 3micron for a final filter. Will be frame rail mounted eventually with a shield. And no I'm not going to run the dented filter will use a new one.
