Added two more doors.
Leeland
Oregon
Cummins 12v.
The 6.9 is still going in here when it gets nice. It'll eventually be replaced by the Cummins next year. 7.3 isn't doing so hot, tapping, pushes coolant from a HG and rad.
Leeland
Oregon
Well I am finally dropping in the 6.9 with head studs, valve springs, and Russ's torque cam in it. I'll also be going from green to oat ELC. Gonna try for doing some fitting while apart regarding the WH1C turbo. I'm on some what of a time constraint so the 093 May go back on. The 94 engine bay harness is also going in to finally finish the electric back window crap so I'll get my cruise, horn, stereo back.
Leeland
Oregon
And going back together
sounds like the perfect time to add another few doors lol
Leeland
Oregon
Slow going. Finally got a intake/valley pan gasket and moving forward.
Started the test fitting for the cac pipes.
Leeland
Oregon
Took the opportunity to try and reseal as well as wrap the up pipe.
Leeland
Oregon
Got the last of the heat wrapping done. Finally moving the GP relay. Got a idea of what's gonna happen, installed the mount on the 6.9. Routing it and re wrapping the harness tomorrow. Along with the relay move some changes are needed for the fuel filter circuits.
Leeland
Oregon
Separated the GP's from the sensor harness. From the separated the fuel side from the rest of the sensors with the exception of the pump circuits. The fuel side is getting routed down the frame rail to the filter heads I'm putting in. Wrapped the engine sensor circuits in a fancy cloth wrap Detroit uses and am about to install corrugated loom before finishing up the GP's and reinstalling the front end.
Harness all done
Installed, GP's done as well.
Leeland
Oregon
Had some insulation laying around from a warranty job on a new autocar. Figured some is better then none.
Fitting pipes, happy on the lay out on this side. Does need some tweaking though and uniformity on the clamps. The other side is going to be a real pita.
Leeland
Oregon
Got the beach side routed. Ignore the missing boot. It's time for a shower and booze.
I would Jasper. Just thought I saw something about needing it for cruise not just the trans. I haven't looked into the legitimacy of that, when it comes to the crummy I got too many irons in the fire.
Leeland
Oregon
Got it to fire. There's a few things to finish up yet and a couple things to look into.
Leeland
Oregon
After backing off the timing. Initially was at 11.3*, still need to recheck.
William88
Staff online
