94 f350 idi 7.3 turbo diesel air intrusion???
replace every single rubber line.
mine started doing the same a while back, i traced it to a kinked rubber line that went to my WFS which was bi-passed.
replaced it and no air.
check the entire line for leaks.
at this point, i would even disconnect everything and blow air through the lines to make sure nothings blocking it.
water fuel seperator.
but yours is most likely on your fuel filter, on my 87, there on the driverside firewall
dieselmainiac
