Some updates.
So, I got the hypermax exhaust done. Actually didn't hurt the turbo whistle to bad. However I think thats because of the cone K&N that I have on it right now. The truck is now even quieter than it was, and I love it. Cruising at 2500 RPM I can have a conversation with my passengers with out raising my voice. Before I was yelling just so people in the passenger seat could hear me. I like it!!
Next, I did the SMF because I thought my DMF was rattling itself to death. Turns out the noise I thought was the DMF was not at all. Now I am thinking valve train noise.... This sucks!
The waste gate was set at 6PSI from the factory. By set, I mean crimped. I drilled out the crimps, and ended up breaking the rod of inside the rod end... opps
I simply cut 7/8ths of an inch off the rod end, than welded a 1/4-28 x 7/8 stand off (or union nut) onto the rod end. Guessed at the length the rod needed to be, and now she is boosting 8PSI, I am going for 10PSI, so I will have to adjust it some more once I get a trailer hooked up to it!
I turned my IP back to FACTORY settings....
Hauls ass. No other way to put it really. Hills that I would have to down shift empty before I could cruise in 5th gear, and accelerate easy, with the EGT's under control. From here I will go up one flat at a time until I am happy with my EGT level, but that also needs the trailer for more tuning.
LAST!
I put about 50 miles on it and the last 10 or so it started leaking diesel in the range of GPM. Its insane. I got home and it was dark out, and have been working from 6AM to 9PM ever sense so I have not even popped the hood to see where its leaking from.
Also, I just plumbed the CDR down to the ground, and now it looks like my truck is smoking at stop lights.... Not cool. Need to figure out a legit intake ASAP! (I might band-aid by pluming the CDR into the filter I have, but would rather make a intake, will have to see what $$$ will allow this month).
Any ideas on the valve noise. Sounds JUST like loose exhaust manifold on my old 2.5l wranger, but the manifolds are all tight!
PZ
