cheaper to keep her!!!
did an oil change,
oil was black black, but the good news was there were no metal shavings on the magnetic drain plug!
the noise i was hearing on the pass side seemd to be a combination of things.
the alignment guy isnt very knowledgeable with after market steering, he had it adjusted down a little further than it should have
resulted in tie rod to drag link contact.
tyweeked it, and its all good now i think.
also the passenger side fenderwell was rubbing on the front body mount,
a quick zip of the cut off wheel and done.
gonna change the water, and then add coolant.
charging issue?
i need to learn to tighten ****.
the alt + cabkle has been arc'n on the post since i started it up lol
