80-91 stripped steering wheel nut threads options
Austin86250
idaho
My manual tilt column steering wheel nut threads are done, I have a non tilt manual that’s good what are my options here? Can I put the tilt on the non tilt? Can I swap the shaft inside the column?
Would love to keep tilt here
Rdnck84_03
Kansas
The non tilt column doesn't have a u joints in the shaft.
I had a tilt and non tilt for a manual both disassembled last night, I was trying to swap the aluminum piece that the lock cylinder goes in.
I was trying to do exactly the opposite of what you're doing. I was trying to retain the non tilt column so I don't have deal with the weak switch actuator in the tilt column, that and I never adjust them anywhere other than straight anyway.
I didn't find much that was interchangeable.
James
Rdnck84_03
Kansas
As long as it is a tilt column you should be able to swap the shaft.
James
Just swap the whole column from a wrecking yard, doesn't make sense to gut it
onetonjohn
California
If you have tilt without slop, I might fix it. The aluminum in housing gets wallowed out and you get slop in the wheel. Presumably they get wallard out from yarding on the wheel pulling ourselves into the truck. Likely ones from the wrecker will have slop.
KansasIDI
Hopelessly addicted to IDIs
Wilsey, KS
Another option is to go sit on a stump behind your shop and cry. Hitting stuff just hurts your hand.
Idk where he mentioned hitting stuff??? I don’t get it I guess… crying might make you feel better, usually doesn’t get the job done though.
What you don’t have stumps behind your shop? 5 gallon bucket upside down? Use that? Hmm?
Austin86250
idaho
If y’all have any manual tilt columns for sale and are willing to ship let me know
What about using a center punch and punch dead center of the shaft. Then drill down into the shaft, and open it up to the proper size to tap threads for a bolt to hold the wheel on? You could use a bunch of washers or make a sleeve out of a piece of pipe to fit under the washer and bolt to press against the center of the wheel. The splines hold the wheel while turning, the bolt would just have to keep the wheel from sliding off. I don't remember how large the shaft is, but a 5/16-18 bolt should be good enough. 3/8-16 would be even better if you still had plenty of meat left in the shaft.
On my dad's old truck before he wrecked it, I had used a tap to make the threads one size smaller, and replaced the nut. Worked like that for the remaining 5 years he had it. Just an idea.
I know you meant Die correct?
Tyler9828
Staff online
