Diesel Max
93 F-250 4X4 - 7.3
Few questions guys......................
Preference on Motorcraft or Napa water pump (one better then the other) ???
Do you need the Water pump gasket or just gasket sealer or Both ???
Fan Clutch..... is it a left hand thread to remove ???
Anything else need to be removed other than the fan shroud, fan, fan clutch, belt and pulley in order to remove and replace the water pump ???
Thought about replacing the fan clutch while I had it apart but $170.00 for a severe duty fan clutch !!!!!!!!!!!!!!!!!!!
Thanks for the input.............
