So David you guys have a repair shop?
Not officially, but I do have the ability to perform nearly every kind of auto repair in our shop. I did a SMF conversion on a 1995 powerstroke for one of our customers once. That was the only time I did any work on an out of house vehicle and boy did that thing need work
(brake lines, U joints, coolant and rear shackle was broken in addition to a failed DMF).
I've done engine and auto tranny rebuilds in our shop and there isn't much left that I can't do. We normally have a fleet of 4 vehicles running at any given time and I maintain all of them. 2 work trucks, and 2 DDs.
Normally I should be building aluminum railings for new houses, but houses aren't being built as fast as they used to.......
One of our regular customers just dropped a semi-rush (non railing) job on our lap yesterday that might be enough to give as a good start to 2009 so we're happy to oblige. But the project will require all of the shop space, so I need to get the diesel ranger running again ASAP.
The engine is almost back together now, I just need to get some camshaft caps for the OHC and might opt to replace the camshaft as well. Aside from breaking some of the rockershaft mounts, the rest of the internals were perfect. You would not believe how hard it is to turn that thing over with a breaker bar when all the valves are closed....lots of compression
I think it will run well when its back together. There were many little things that added up to try and kill it (mainly just lose bolts).
