Well I picked up another pony or so. Since th EGTs stay higher for a little longer after a hard run, the turbo seems to be responding a little better. Peak boost numbers have not changed, but throttle responce sure has......
I managed to break traction on an uphill turn at 30 MPH at less than half power (about 3 psi!!!). That doesn't happen very often even if it was wet pavement.
Acceleration from 55 MPH is a little interesting. Press the pedal down about half way and wait.... The boost jumps to 4 psi but as I pass 60 however it climbs to 7 psi without any more power added while pushing you back further in the seat. It almost feels like the a mild after burner kicking in.
And for the final test, I floored it up a 10% grade to see what it could do. Normally 70 MPH is the best it could do. However this time in the approach to the steepest portion of the hill, I had to back off because a turn was comming up. After the turn I was on the 10% hill and went all out. for a few seconds in held steady at 70, but then gradually started to drift up closer to 75 MPH.
Peak boost that I observed today was 11PSI and EGTs maxed out around 1050, but it just moves a lot harder under those same conditions and smoke seems to be a little lower. If I really get on it, the turbo just screams. Performance in overdrive seems to be decent too.
Yeah guys, theres a difference. I think header wrap is a worthy investment for $50CAD
Although the collector pipe leak probably didn't help much before either, haha.
