So anyway as the nightmare unfolds....
I have a one cracked head on my 6.2...well that was a suprise that both weren't cracked. But I do have a 6.5 that vomited its bottom end And that means I can play the craps table once again on yet another set of heads. So...the 6.5 heads are removed and are shipped off to my local cylinder head shop so I can get another "deer in the headlights" look once again. I compared the head bolts between the two...they match in length. Definitely will be using the 6.2 head gaskets. Anybody dropped a set of 6.5 heads on a 6.2? Mind you, the 6.5 turbo setup will be residing on the motor too. With a TEO6H Banks off a IDI to make matters more complicated This is gonna be one very interesting ride when I finally get through with it
