Diezel_Cowboy
It's not like a real ***!
I have a vibration while in 4x4. It happens with the hubs locked in and happens worse when 4x4 is engaged.
I inspected the situation and found that what they call a "double cardan joint" (the double U joint that is in between the front axle and the transfer case) is loose. It doesnt appear to be worn but i can move it in a circular motion.
My question is has anyone ever torn into or replace one of these joints? Can I just replace the two U-joints or do i need the whole front shaft? There is an H-shaped coupler that joins the two u-joints together, but it looks OK. Any experience or advise on this subject would be helpful, thanks!
