6 Nebraska IDIs
- Joined
- May 27, 2007
- Posts
- 4,247
- Reaction score
- 15
that thing's gotta be real easy to park in some of these new import sized parking stalls.
I have a triangular looking plate with a few bolts that will need to attach somehow to the engine crossmember. It comes from just behind the U-Bolt shackle of the leaf on the passenger side. Do I get an adapter, from where? Forgive my ignorance .... but, whats it called?
if only you needed the someone to measure a c6/np208 combo, cause i would.
anyways does that rig have the twin-I-beam frt end in it? or is it monobeam?
Track or tracking bar is the name.
Here's a pic
A ZF 5spd would help, they are pretty short in case length.....In your case it might be more work as you don't have a diesel crossmember now....Pretty much all of my stuff bolted in place (after I drilled the millions of friggin holes... ).....The track bar is there now....It just wasn't on in that pic. I haven't had the truck lined up yet but it drives fine....I hope to have it out for a test drive late next week if all goes well....I can't wait to "take a gear" with the 5spd and crawl in low range like a tractor.....I'm starting to look at a pair of 4" stacks as my next "improvement"....I have $2500 into the 2wd to 4wd D-60 swap , NP205 install and 5spd swap so far...All paid for by selling parts from junked Ford trucks.
I dropped the 205/steel off today so Jim could finish off the crossmember on Sunday...He's coming back over on Tuesday night to mount it and make the trans crossmember and shifter handle mount.
I think I can squeeze a married NP205 in place. It is hell sometimes, just getting a simple dimension. I've put in a yr. on the swap, and still don't have it. Oh Well, everyones intitled to an opinion. I just need a dimension, to be able to run the doubts off the road. I need the married NP205 C6 total length. Why do it ? .......................... 1st, the added weight to the front, is needed, the truck is squirrely, and needs some front weight. 2nd ........ It is my opinion, that this will help solve said issue. 3rd, ............ A heavier engine, just won't solve the 1st and foremost goal. The reason comes from Houston Texas freeway traffic at 80+ mph, Lets just say ......... I don't bother dodging Geico squirrels. This dimension is not critical. I know one thing for sure.... AnyThing Is Possible...... That is why I continued. I know how engineering works. I have a good working knowledge of the principles of mechanics, & I think it will improve the overall performance of this TRUCK.
