Which way are we pointing here.... How can I attach to the '81 4.9L engine crossmember .... solid '94 Dana 60 ball joint w/leafs, replacing 2WD Kingpin IFS/TTB w/coils.
I've never done anything 4WD or even owned, much less driven a 4WD. What do I expect I should know before performing this swap? I have all the parts, here & I am just needing advice. I am mostly, lacking in, a knowledge of part descriptions & terminology. I just got the front shackle hangers, and I am waiting on the dually hub replacements, which I'll change after the axel is in place. You guys have the experience, that is why I'm here, to grasp the reality of this setup. You gotta keep in mind, I'm doing it myself, because the local 4wheelers, won't do the job, saying I will have a driveline angle problem. I don't think so, as long as there is no lift difference or very little. My rear drive shaft is 16 3/4" long. Whats the big deal? Whats the length difference in a C6 vs. a 4WD C6 w/married NP205. Which I will get down on, after the front is in. Just guessing, I'm gonna say about 3 3/4". Wrong or right? I don't believe that Ford would go to that much of a difference in the factory setup distinguishing the difference in them. I just would rather it be an automatic, for the ease and comfort of driving, than do a standard tranny swap. The C6 length difference will either way, justify my Dana swap on the '81 F350 BobTail Dually. Can't wait for the answer !!!!!!!!!
