Hmmm, well, your situation is 200k on the trans, and plastic parts could very well melt/flow over time.
The remedy makes sense. I think if you can keep trans temps under control, that the plastic part would
last, but that's a logical guess. If you have chance to improve it, then do so.
One thing to consider, by just putting in a Boost Valve and Spring into the Pump, you will get much better
performance out of your transmission overall. Even the OD problem could clear up just from that one action.
Overall you will notice a change for the better.
As far as building for 600+ HP and Torque, I am not too into that, I just want to have a durable trans,
and upgraded from all the bad things in the pre-95 models. The stock E4OD HD built to '97 specs is
quite good and better in just about every way than the predecessor, the C6.
For me, I've picked only those mods which are upgrades for durability and moderate power. Is the Superior
kit for durability or power? I don't know too much about it. I looked at Front Pump issues and doing the F5
from the E9 was enough for me, plus the TransGo kit helps exploit the added capabilities of the Pump.
******just for giggles******
Here's my C6, original factory trans, DIESEL:
(Previous owner was nice enough to keep the Case and Output Shaft pieces in a bag for me...)
(The reason I love this C6 so much, is it saved me a ton of money when I bought the van that it came with...ha)
(Actually the C6 is one STOUT F-n trans, if it only had an overdrive and lower first... ...oh wait, that's the E4OD!)
