SuperDave
I've got a '94 f super duty with the parking brake drum on the transmission, the parking brake does not keep the truck from rolling even on flat ground and it also seems to have a slight leak. I've had the drum off and the shoes looked good and the cable is adjusted as far as it can be but it doesn't work at all. Are parts still available for these? I assume I would just need a set of shoes and new seals to go back in it but I'm not coming up with much info and could use a bit of help! Thanks
