EMD_DRIVER
Say what?!?!
Ok guys... I am looking for some specific info, for my ZF 5 swap. First, I need to know how much shorter the front drive shaft needs to be. I also need to know how much longer, the front section of my rear drive shaft needs to be.
There's a red two-wire connector on the side of the tranny, that I'm assuming is the connector for the reverse lights. Anyone know of a part number for the connector, so that I can wire this up?
There is also a pigtail with a connector on the end. What does this go to?
The Transfer case has a hole that I believe is where the speedo gear goes. Since my speed sensor is in the rear diff, what can I put in that hole? Should I just use the transfer case, from the E4OD?
I found a new SMF clutch kit on the NAPA web site. Is this what I need?
Item#: NNCMU19891SK
Clutch Set - New
That's all the questions I have right now... There will be more to come..
Item#: NNCMU19891SK
Clutch Set - New
