BigRigTech
Diesel junky
A few pics of this weekends Dana 60 front axle swap carnage. (That's the old man in the pic, not me...) 7" of lift over the stock, sagged 2wd in the front, 4" in the rear....Load's of work, more than I expected. Took me and the old man 7hrs yesterday, 2.5hrs last night by myself and another 7.5hrs today for me and the old man, we are pooped but we took it for a drive - mucho F'n cool.....Still needs the steady bearing shimmed down, gotta drop the driveshaft some to stop a vibration we noticed/expected. Next up is the NP205 transfer case install.
It went in fairly easy, no stock 2wd hangers or brackets were needed by the engine mounts so they were removed completely. The only snag I had was on the wheel studs.....The 4wd studs were too long once I removed the spacer that was on the D60 hubs for the previous 19" wheels. The 2wd studs were the right length but the "teeth" were in the wrong spot to grab the hubs.....$50 at the dealer and I had new wheel studs. Made up some brake line brackets, had to re-use the L/S hose (junction block )....I also mounted the shock mounts 3/4" lower on the frame to compensate for the higher than expected lift.
It needs some minor adjustments-tweeking but it drives ok and brakes good....It's a 40 acre truck now - doesn't turn very sharp. I posted a pic of the shackles too so you guys could see that they aren't sitting too straight...The springs were arched 2" over stock and the 3rd leaf was added. I havent' decided on wether to put the sway bars back on or not - might need longer links in the front.
