Doesn't surprise me, while the mileage is low - the truck didn't see intensive maintenance for a while.
So I pulled the truck into my garage so I don't freeze while doing the brakes later this year - started to run funny...
First it started missing, okay I just replaced injectors so I figured a seal was damaged on the return lines...
Then the bizarre event, truck would change idle from barely running to my guess of 1k. Every 2 seconds like clockwork the idle would shift.
I'm thinking it's the IP, would explain the initial missing that occurred.
Also didn't want to shut off until after the same 2 second cycle.
Anyone else have some insight?
