water pump then radiator
razorback
branson, mo
yes factory one. the one that was in there was a gasser thermostat, it needed to be replaced anyway. and the gasket i meant was the one around the flat part, not the lower part. the rim i guess you would call it.
69dieselfreak
well that nice
rimrock arizona
exactly the on i was talking about i took it off left the lower on on
69dieselfreak
well that nice
rimrock arizona
ok is this normal or not
185 water temp going down the road what is to hot
45psi going down the road idle 20ish
oil temp follows the water temp basically
whats u guys thoughts
mydixiewrecked
