Get you some string to fab up a mock up to get close. Buy some bigger and smaller, then return the ones you don't need. Easier than running back and forth with one belt trying to find one to fit. (Ask me how I know :lol )
lol ill def try that. I dont know why I didnt think of that in the first place. I am always amazed at how many times we rack our brains and go through tons of work thinking of a million things it could be; and it end up being something small.
Just like when my belt originally went, I was on my way to graduate class and noticed the volts. Racked my brain all day in class thinking it could be starter going out which is why its hard to start, battery terminal corroded, batteries going out, or alt going out.
Then after a few days of everything testing fine, I notice its just the damn belt missing as I didnt notice it behind the other two
I also have to replace all my positive cables and negative/grounds and still trying to find the seller on ebay, or if it would be cheaper to go through tousley ford or try and order stuff to make my own smh. Also do you think it will bother anything with one of my valve cover gaskets being off sitting in the garage? The gasket went bad but for the time being I just set the cover back on in the garage until I get around to replacing it with everything else.
But curious beens its been cold, and that is no longer "sealed" between the cover and top of head; if it was cause moisture to setup in there in the oil? Maybe just me overthinking things!
