I just thought I would pick your brains for some ideas. I am
looking at installing a turbo on my truck. Doing some
research, I found that it's really hard to run more that 8-9
psi of boost on these engines because of the high
compression ratio. I understand that the newer trucks are
running 17 or 18:1 compresstion to allow for more boost.
There are low compression pistons I can buy for my engine,
but I have been told that this will cause hard starting for
these engines. My question is why? I understand that a
diesel need compression to fire, but how are the new diesel
different that allow for easy starting with lower
compression. I'm sure the computer helps, but what exactly
does the computer to do the engine to make it start so easy?
How did Cummins achieve a good starting engine with 17.5:1
compression and NO computer back in '89? Did they have the
glow plugs stay on longer?
I'm not looking for a parts list of things I will need for my 6.9. I am looking for the theory behind the hard starting issues. What do the other trucks specifically do, or what differences are there that make these engine start with lower compression?
Tim
Tim
