1983idi
So does anyone know if a sway bar system from a 1989 F350 Dually 2wd can be put in a 1983 F250 2WD. I'm chopping up the 350 for scrap and was thinking I wanted to put the sway bar on my 250 if possible.
On a side note I noticed there is wires going into the top of the center section of the differential. The truck didn't have abs as far as I can tell. And the speedo cable goes in the rear of the transmission. Is it possible the truck has a locker in the rear axle? or is it probably an abs speed sensor?
