skipping engine?
7.3 man
7.3 idi man
Branchland,West Virginia
Our 1999 f250 has 91,000 miles on it everything has been serviced, but it has a skip, just so faint you can feel it, but when ur running, it feels like, the timing isnt right, cause the skip is there when hot or cold and bout 1/2 a sec long, what might the problem be? Its had all the serivicing done and it just about two years ago had a recall for a cam sensor, and it started actin up ever since then :)
Pull the valve covers and check the UVCH connectors, might be comeing loose, known problem. Get this CPS from IH dealer and try it. 1876736C91 Blue or 1866735C91 Gray
