Rear Tank fillup
Today I finally to to refill my rear tank after the fill modes.. it took 19.821 gallons... As I recall its a 17.2 gallon tank...... Also I can't run the fuel fast. It still spits back... I have a 1/2 inch hose on the top of the tank where the roll over valve was... I'm thinking its the steel spout that the nozzle fits into when flling. The front tank does the same thing after the modes. At the very end of the fill neck there is a roll in the steel connecter that acts like a cup on the inside of the tube. I'm going to cut that off so the flow will not be interupted and see how that goes. I wont be cutting this lip off completely. Its there or any type of wreck so the rubber hose doesn't get pulled off the metal spout.. I think.....
F350farmboy
The Hornet
N.E Ohio
Yeah, I did the mod to the rear tank and I still cant go full tilt, although I can completely fill it up while manually holding the lever. Takes about 1 min or 2 to fill the rear tank...very worth while IMO!
