radiator help!
pt_Ranger_v8
Vegas
Can I use a radiator from a 351w to cool my 7.3 n/a idi? Some dirty so and so stole the one from my parts truck -cuss, so I don;t have a diesel radiator anymore. What are my options? $300 for a new radiator, and fabbing up a core support isn't looking too appealing at the moment :backoff.
Suggestions?
itsacrazyasian
residentcrazyasian
boca raton, fl
wait are you trying to use the 351 and gas support?
If you are.... you will need to merge the two hoses together, i used some piece of exhaust pipe and welded ribs on the end to keep the hoses from sliding off.
I am running a 4 core HD gas radiator and i'm just fine. Turbo, not intercooled and air conditioned. Running a BIG crown victoria cooling fan though.
pt_Ranger_v8
Vegas
Ok. I just wanted to hear that someone else had done it. ;Sweet I'll find a fan at the pick and pull tomorrow, but at least I can get my radiator plumbed, and the rest of thee swap finished.
i wouldnt try it a little to small. fork out the beans for a new one
I would love a diesel one, but I've already got to do driveshafts :rolleyes:.
itsacrazyasian
residentcrazyasian
boca raton, fl
I'm still running the gas 351 4 core brass radiator with a crown vic two speed fan. Even with the warm days here and the a/c running i'm ok. So far the hottest i've seen is 210 in the overtemp position doing light to light hard throttle runs with 10K in tow. I have a spare diesel rad and core support but i'm just not in a hurry to replace it.
flareside_thun
Reviving The General Tao
Tavares, Florida
Those e-fans flow quite a bit of air also.....3k CFM ain't no slouch on anything. You do what ya gotta do to get by sometimes and it ends up working out great.
pt_Ranger_v8
Vegas
Coo. Thanks for the help guys. Overall, this swap isn't going TOO badly. I wish I would've measured my trans first though. The ZF-5 is 5 1/8"shorter than the AODE, so I had to fab a x-member today.
flareside_thun
Tavares, Florida
Any reason why you didn't just slide the x member where it needed to be and then redrill holes? I take it you're doing a diesel conversion? I wasn't aware that the AODE came behind 351W's......my 302 got cursed with it...what a pain to find parts.
pt_Ranger_v8
Vegas
AODE never came behind a 351w. C6 or E4OD
Yeah! that one!
I always get those two confused. And I can't just slide the crossmember forward, because of my steps - they're bolted to the frame. -cuss. If I had known, I wouldn't have put my steps there 6 months ago.:backoff
nsjames
Yeah! that one!
no thread on Pirate re: the swap?
I managed to make it over here from there researching Uhaul motors. 4runners thread has me inspired.
pt_Ranger_v8
Vegas
there is. crew cab fab in the ford section no pitures, and not many updates though LOL
itsacrazyasian
residentcrazyasian
boca raton, fl
Well depending on what you're towing you might need to do the diesel rad swap. I did find the outer limits of my gas cooling system
