Pipeliner_86
IDI up high
Does the vehical speed sensor also act as an ABS sensor? Or is the proportioning valve dohicky mounted on the frame rail the ABS? If so there are no wires attached at the valve, also there appears to be a linkage rod missing that would connect that proportion valve to the rear axle.
My speedo works, yet the red and white twisted wires that go to the VSS are cut, well just the red one is cut, the white is not. I would think my speedo would not function with one wire cut.
I did replace all brake pads and had drums turned and one new rotor. I bled the brakes, but still the pedal is soft. The truck will stop with no problem, but I think the brake pedal should have more pressure to it. Would the missing linkage rod at the rear axle account for less rear brake power?
Any advise would be appreciated.
By the way, since I joined this site, everyone has been very helpfull. Thanks a lot guys, I have recommended this site to my freinds.![thumbsup :thumbsup: :thumbsup:](/styles/default/xenforo/smilies/cool guy.gif)
