Pre VS Post pyro......
geonc
SPIDER BAIT
NECKVILLE North Carolina
WHOLY SH------NIKE:eek: what a difference...and temp seems to build QUICKER:eek:
every bit of 300 degrees difference.....pulling a reasonable grade at 2800 turns at 80 mph--14 lbs boost/800 deg.................... and bury the pedal... 25 lbs boost and can easily pass 1300 deg:eek: :eek: barely made 1k reading post turbo stack temp.
Same Auto Meter 12v powered pyro guage and thermocuple....just moved from post to pre when I had the engine out....easier to drill the collector flange:D
Exh is WIDE open from gutted EBPV back,,,,nutin' but hollow pipe.
DAYM........
94f450sd
somewhere,ma
yup time for an intercooler :D although i can still hit 1500 degrees easily even with the IC but it takes a little longer to get there as opposed to no intercooler
FaC
Central NC
I never had the post but I was amazed when I put the pre-turbo pyro on. I was seeing 1350 on a stock 7.3 6sp pulling a TT going eastbound on I-40 just past the split with I-85 in Durham (really EASY grade). Of course that revelation led to more expense - I ended up putting on a Walker BTM. That was a cheap way to get 50-100 degree lower EGT. That made a big difference for not much money...
FaC
Mike
Stroker
Cora
Yup....... pre is the best place and this is the reason geo.
Mark Craig
Advertising Sponsor
Franklin, TN
geonc,
Been saying this for years, now go get a trailer and a 4% grade and be in a hurry! You'll see a 600 degree difference really easy!!
Mark @ DPPI
