geonc
SPIDER BAIT
WHOLY SH------NIKE
what a difference...and temp seems to build QUICKER
every bit of 300 degrees difference.....pulling a reasonable grade at 2800 turns at 80 mph--14 lbs boost/800 deg.................... and bury the pedal... 25 lbs boost and can easily pass 1300 deg
barely made 1k reading post turbo stack temp.
Same Auto Meter 12v powered pyro guage and thermocuple....just moved from post to pre when I had the engine out....easier to drill the collector flange
Exh is WIDE open from gutted EBPV back,,,,nutin' but hollow pipe.
DAYM........
DAYM........
