pwjackson
Okay, drove my truck about 12 miles the other day and then let it idle for about 10 min while I hooked up a trailer. (no lights I might add). I pulled away and moved about 50 ft and then the truck died like some turned the key off. Went to start it and got nothing. No power to gauges, or starter relay on the fender, had power to glow plug relay and brake lights that is it. After several minutes of fidigiting around it started. Don't know what I did but I have drive it a few times since and all is well, no problems. Could my ignition switch in the steering colum be bad?
