PLUG ON TOP OF WATER PUMP USE??
chris142
SoCal
If you replace the stat put a small piece of paper in it to block it open slightly. This will help prevent an air pocket.
DiecellDan
Tx
Is removing the check ball in the thermostat housing okay? I lost the check ball
Macrobb
North Idaho
Yes, and it works so much better with it missing.
So an air bubble is equal to a blown hg?
That isn't necessarily being "extremely hot" either.
In my experience, an air pocket will escape during warmup, not usually once it's hot - everything will have already expanded by then.
A bubble or three, sure. If you get constant bubbling(which is what I was thinking of when I made that post), or a bunch of bubbling right after "overheating" it, you might well have a partially blown head gasket - that's what mine did for about a year(slowly getting worse) before blowing to the point of coolant out the exhaust and a "boiling" overflow at idle.
kbeck
