Out with the old (Autolites)
EMD_DRIVER
Say what?!?!
Beaufort, SC
Did my first GP change-out this evening.. ;Sweet Since I never met the PO of this truck (The 93) I had no idea what I would find. I knew I had two burned out GP a couple of weeks ago and h20drx sold me a set of true ZD9's (Thanks again! :hail )
I started with the #2 cylinder and it came out fairly easily. I would imagine these old ones were put in with anti-seize. #4 cylinder presented me with a problem, since my swivel/socket combo was way too long to go over the GP. I removed the clamp that holds the lines together, as well as the #6 injector line from the IP. The line was nice enough, to move itself out of the way for me. I know these steel lines don't give, they tend to break.
Every one of the old GP's came out fairly easily. I breathed a sigh of relief and said a "Thank you" prayer, after the last one came out. :thumbsup:
I put some anti-seize on the MC's and stuck them in. Hooked everything back up and gave her a try...
WTS light stayed on for exactly 8 seconds and she fired right up! I ran it long enough, to make sure I worked the air out of the #6 line. Shut it off and put my tools away (Good boy! :rock: ) When I fired it up to put it back in the driveway, the WTS stayed on for only 6 seconds... with no more click..click..click..click..click after the WTS light went out.
I did notice that the voltmeter stayed down around 10-11v longer than it did before, but not more than 10-12 seconds after the engine started. Before I changed the GP's, it would be down there until the WTS light went out. It would then click down, coinciding with the GP relay clicking.
Of the 8 I removed, 3 were burned out. You can plainly see which 3 they were in the pics. I laid them out, in the order they were removed. The bottom of the pics would be toward the front of the engine. 1, 5 and 8 were burned out. Also, these are what they look like after 2,500 miles on 50-70% WMO. They look worse in the pics, than they do in real-life.. :dunno
zpd307
Zumbrota, MN
good to hear it worked out for you. today was the first real test of my glow plugs. the truck had sat for almost a week, it was pretty cold last night, right around 20, high teens. it was 28 when i went out to start it, to pick up the kids from daycare. anyway, she wanted to fire right away. i found myself letting go of the key too soon. but she did. so at least i know the glow plugs are still decent. but like you, i have no idea how old or what they are so i am probably going to change them out soon enough.
Dsl_Dog_Treat
Decatur,MI
Glad to see you didn't have too many problems Gary.;Sweet
I wished Mater's would have came out that easy and looked that great.
2 Champions and 6 Autolites.
Champs came out easy, 4 Autolites didn't as 3 had swelled tips and one had been overheated so hard that it bent itself from the extreme heat.
Took 45 minutes to get that one out.:puke:
He's got Berus in there now tho.;Sweet
EMD_DRIVER
Say what?!?!
Beaufort, SC
45 minutes for one plug?!?!?! I've heard other horror stories, just like that..
This job took 28 minutes.. Start to finish.. All 8 of these were Autolites..
Bo17
