Oil leak
Fullsize4life
Now with More Smoke
Mich
Ok i got a bad oil leak on the drivers side of my motor. When i fire it up and let is idle it will start dripping down outa the cross member and onto the front pig. Oil filter is tight. Pan is good. Where else can it be leaking from? Is there inlets to the oil cooler down there or what? Im stumped?
Thanks
Cincinnati Guy
Cincinnati, Ohio
I would look at the oil cooler. You sure its coming from the drivers side, or maybe its leaking elsewhere and flowing over the crossmember?
wbw189
Metamora, Michigan
I agree with Ryan. Trace the leak up. Way too much money can be spent from the bottom. Pull the inner fender to help diagnose, it's easier of the two. I just pulled by front clip to do some R & R. Uncovered a few gems that could have given me a lot of grief (oil cooler, power steering seals, valve cover gaskets, cut battery ground, rag joint, shocks, ...).
THECACKLER
Da Central U.P.
I'll bet on the front outer Oil Cooler O-Ring. Mine just did the same thing. Looked just like a leaking X-member. The cooler had been a slow leaker ( only when cold ) for over a year but I put it off because somewhere I read ( mistakenly ) that they don't fail catastrophically. Well I'm here to tell you they do. I could see the oil spraying out from the gap between the front OC header and the big O-ring ( IH # 1804414C1 ) at idle. I checked the oil level and then restarted it to move it approximately 200' to where I could tear it down and in less than a minute blew out another 1-1/2 gallons of oil.
hesutton
The Anti-Anderson
Bowling Green, KY
Oil cooler, valve cover, or the oil supply to the turbo. That line can easily get a hole in it if have been in contact with firewall, tranny, motor or whatever on its way from the lower driverside of the block up to the turbo.
Heath
Fullsize4life
Now with More Smoke
Mich
My oil cooler line is braided stainless. Im sure it is the oring on the oil cooler now that it has been said. It is going in next week for a fix
Fullsize4life
Now with More Smoke
Mich
Oil cooler is shot. In the shop now. Should have it back on monday. Not cheap and i did not have time to mess with it.
Fullsize4life
Now with More Smoke
Mich
Getting a new cooler off of a 7.3 out of a bus. In very nice shape. Hope to have back tomorow after noon.
