Good to see another one being saved. You've got one major item to address. Your core support is gone. At least on the drivers side. Pull the front clip and cut the rust out and weld it back up. It will last forever if you do that. If you don't, your fan will be hitting the shroud and it will fall apart on you in short order. Just did this on a 94'.
