LCAM-01XA
Was at the U-Pull-It looking for a 3G alternator, and in the medium-duty section there was this bricknose crew dually F350, as I was walking around it I notice on the ground what looks like a Sterling axle differential. Looked up close, and sure enough, she's a limited-slip!!! Look under the F350, yeps, diff is gone, but bearing races are there still - crawl under and grab them and the fit the diff perfectly. No gears, I guess that's really what them folks who pulled the thing were after, but I got my 4.10s so extra set of gears I do not need - what I did need, however, was a limited-slip diff
So I guess it is indeed one man's trash is another one's treasure, I took this thing home for just $20 and I couldn't be any happier
So now I just gotta clean her up nice and pull the Lincoln locker out and put the LSD in. But before that, is there any way to check if the clutches are any good? Also how the heck do these differentials work anyways, there's no S-spring inside them like there is in the 8.8 differentials used in halftons, what pushes on the clutch packs to make them engage?
