ISO: 5/16" e4od cooler lines & adapter fittings
Cubey
Van dweller
USA
Needing E4OD hard lines in 5/16".
From any vehicle will do really, because it's going on a 1989 IDI van, where I'll have to do some light fabrication (probable bending, length adjustments) anyway
I think I'm also in need of the adapter fittings between the transmission and cooler lines.
Trying to clean up this mess from a past owner.
The green circle and "?" markings turned out to be going to a spin on filter that just out of sight, hence the excessive mess of hoses.
The hard lines are mostly gone and what's left there is very short and in the worst places clamps wise. I need to just rip it all out and start over, with less of the $4.60/ft ATF grade hose than it uses right now... which all looks way beyond needing replacement.
tke395
