Intake temps
oldblue05
PIN IT TO WIN IT!!!
Caldwell, Tx
I am going to install an air temp gauge on my truck, I was wondering what the intake temps I should expect when I get my ats turbo on my 7.3 running. I'm plannin on running an air to water inter-cooler, which is the reason for the gauge, it will tell me if the pump quits on me... plus it'll be cool to know how much of a difference it makes.
I ask because I don't know what temp range I should be looking for, I found some on ebay that go from -22-158 F. I'm pretty sure with Tx heat if my intercooler isn't running my temps will rocket way past those temps.
They have tranny temp gauges that go up to 300, does anyone know if the sending unit would work in open air?
SparkandFire
We're drinking beer
Aptos, CA
If you've got a little cash to spend on it, something like this is really nice...
http://www.omega.com/ppt/pptsc.asp?ref=DPi_Series&Nav=temm02
Then a TC-K-1/8NPT-U-72 thermocouple...
http://www.omega.com/ppt/pptsc.asp?ref=TC-NPT&ttID=TC-NPT&Nav=
Cool thing is that the digital ones respond INSTANTLY to changing temps, not like the analog gauge that has to move slowly. And you can have as many similar-type thermocouples as you want, with a selector switch.. So you could monitor anything you want with one instrument...
Otherwise, yes the trans temp gauge sender should work fine... ;Sweet
oldblue05
PIN IT TO WIN IT!!!
Caldwell, Tx
SparkandFire
We're drinking beer
Aptos, CA
That setup looks like it will work, but it seems the label on the back of the meter shows 0-400 degrees C, meaning it will read out in celsius.
It could be configurable with jumpers internally, I don't know... Just know that it may be a little off-kilter from what you're expecting.
oldblue05
PIN IT TO WIN IT!!!
Caldwell, Tx
if you scroll down to the item description the temp range is 0-1000 F... oh wait you mean on the thermocouple... ****, i'll find another one. THANKS FOR THE HEADS UP!
oldblue05
PIN IT TO WIN IT!!!
Caldwell, Tx
wait would that even matter? how could a thermocouple know whether it's reading C or F?
SparkandFire
We're drinking beer
Aptos, CA
I does say that in the description, I was looking at the little silver label on the back of the meter... Some of those panel meters have a jumper block to change the units of measurement, but I dont know if that one does.
For 8 bucks though, I would learn my intake temps in celsius... :D
