Injector Question and advice needed
MidnightBlade
Shiftin' Smooth
Johnstown, PA
Just a tip when you get your Pyro installed, keep the probe in the manifold to get a true reading. I put mine as close as I could to cyl 8 reason being is if I remember correctly 6 and 8 fire one after the other so in theory that should be the hottest part of the manifold (someone correct me if I'm wrong here).
Also something else to look at is the badge on the side of your IP I know at least with Agnems line of Moose Pumps he has the Moose model stamped on the tag. Could be a higher output pump than factory
Gerhard
