I'm getting my second IDI... Need help
EMD_DRIVER
Say what?!?!
Beaufort, SC
I logged 865 miles and burned 67.55 gallons of fuel...
12.8MPG average...
Wasn't what I was expecting... When I got out of the warm and moist air and into the cooler dry air, the truck ran a lot better!
Gary
Double-S-Diesel
parts seller
derry pa
Then that's what it is.. Bradley Roberts and I adjusted the FIPL, but it didn't do a thing.. I have to pull the shifter down to get first, have no second and then shift it up to third. If I try to take off in drive, it takes off in third.. Oh, and there's no O/D-off light... ever..
Gary
There is an elecrical problem , either a power problem, a unplugged connection on the pass side of the trans, or a bad selenoid pack,
common problem is the seloniod pack,
EMD_DRIVER
Say what?!?!
Beaufort, SC
Where would I find this solenoid pack?
Sorry it took me so long to respond.. Been sick in bed, since Tuesday...
Gary
ford5.9
ford5.9
waco/texas/us
And you dont think it may be something as simple as the TPS. I've had them do some crazy stuff before. Start out in second and converter kicks in and out
EMD_DRIVER
Say what?!?!
Beaufort, SC
That was adjusted on Monday evening, to within specs, but didn't change anything. It still won't shift.
I know it's been changed, since it is a gray one instead of a black one.
Gary
tradergem
Arizona
What are the codes for the tranny? Have you disconnected and cleaned all of the connectors to the tranny, FIPL, Tack sensor, Speed sensor, TECA, Barometric Sensor, and don't forget to check the brake system for shorts, grounds, bad connections, and defective swithes.
Jim
EMD_DRIVER
Say what?!?!
Beaufort, SC
Jim
Can I read the codes on the tranny without a code reader?
Only found two connectors going to the tranny.. Removed, cleaned and reinstalled both of them..
FIPL was adjusted to within specs and contacts cleaned.
Barometric sensor contacts were checked..
TECA relay is working..
Still need to check the speed sensor (Rear pumpkin?)
I'll check the brake system tomorrow.. It had a brake controller installed on it at one time, but has since been disconnected. I won't hook it back up, till I get these other issues fixed..
Gary
EMD_DRIVER
Say what?!?!
Beaufort, SC
Ok... Found out how to read the codes without a reader and got the following:
56- TOT reads -40 degrees Fahrenheit, or circuit open.
23- TPS out of self-test range
91- Shift solenoid 1 circuit failure.
92- Shift solenoid 2 circuit failure.
93- Coast clutch solenoid circuit failure.
94- Converter clutch solenoid circuit failure.
99- Electronic pressure control circuit failure.
With all these codes, it sure sounds like there's a broken wire(s) somewhere...
Vincent
