IDI Fuel Filter Heater Temp
Blind Driver2
New Albany, In
How much is the fuel filter heater supposed to increase the fuel temperature?
I'm running wmo and am simply curious. I'm probably going to install a band heater on the filter.
Blind Driver2
New Albany, In
Apparently mine is isn't working. I'm infinite ohms from the heater terminal to the housing and also to the battery :dunno
FORDF250HDXLT
Maine & Oklahoma
the fuel filter heater is just that,a fuel filter heater.it doesn't heat the fuel.it's far,far,too small for such an event.
what that does,is helps keep the fuel from gelling in the filter itself during the winter months for those in cold climates.
today though,the fuel stations get diesel fuel in according to the area cut more like kerosene than diesel here.
so anyway,the fuel filter heater isn't anything that will help you run wmo.not worth the $ to fix.
mine doesn't work either,and i did have my filter plug up on me one winter.however it was due to poor fuel (lots of water from the station) that had froze,and i never had an issue since then.
So are these hot lined and on all the time in the friged areas... Just wondering cause we don't have it that cold out here... But we have "other things"....
Blind Driver2
New Albany, In
It comes on with the ignition key. The wire will be perfect for my filter heater and maybe a electric pump :sly
Bo17
