guages
dirtbikemike
Is there any need for guages on a stock 6.0 with a 6-speed manual? I only tow a small trailer but run it hard through the Colorado passes.
Mastertech
Car Doc
Houston
I don't know that you need gauges, but I like to know as much as possible about what's going on under the hood, so my preference is to have gauges.
jvencius
In a van down by the rive
On my almost completely stock 7.3, I hit 1300 degrees F running through the mountains over in MT, so I can't see why it would hurt to have gauges on a stock 6.0
TooMuchBoost
South of Atlanta
No, especially if you are worried about glow plugs and relays from the 7.3 days (I installed volt gauges in both my 7.3's because of this).
If you aren't running a module (in other words stock) run the p!ss out of the 6.0! I ragged mine out and loved it even modded!
Mike
Stroker
Cora
Guages are always a good idea, especially if down the road you have any inkling that you might do some performance mods. The rule of thumb is always....... guages first.
Welcome to the forum Mike.
timntools
Chief Runinscissors
Hendersonville, TN (Nashville)
I found that on my 04 6.0 my engine overheated, and the exhaust wasn't high...but I've ran the exhaust way high and the engine temp needle never moved.
I'd put in some gauges...
Puddle Pirate
Pillage For Diesel
Walked Inland And Swallowed The Anchor
Gauges can't hurt. Towing my 12,450 lb trailer over the mountains, it provides peace of mind to know what is going on up front. I did increase my CAT back to 4" and that did lower my temps some.
I do not run a module or chip. Don't need to. Still plenty of power to spare, even up the Grapevine in Southern California and the Cascade mountains.
Gordon.
Kyle Graham
Supporting Vendor
Washington state
Guages are a good investment. Monitoring egt's and boost are like running diagnostics 24-7. High egts for a sustained amount of time can melt pistons and crack cylinder heads.
mydixiewrecked
